Re: Re: Adapting rear wheels from another tractor
Posted by Bama Binder on August 25, 2003 at 04:38:16 from (68.17.147.240):
In Reply to: Re: Adapting rear wheels from another tractor posted by Randy in NE on August 25, 2003 at 04:21:20:
Thanks Randy...
I found some wide floatation tires mounted on rims intended for a Ford or Massey Ferguson compact tractor. Price is rock bottom. Application will be for 8 mph or lower usually aroung 4 mph for mowing (IH 184).
The rolling radius is about 8" larger than the 9.5X24s I'm using but the change is relatively small. The radius is about 2" greater but I think there is enough clearance.
I figure if it is withing a millimeter or 2 of center t shold be OK. I may try to find some 5 of 4 1/2" pattern rims that they can cut the center out of and either weld in or bolt on.
Anyway, thanks for the input.
BB
Post A Followup
: Re: Re: Re: Adapting rear wheels from another tractor
