Re: Need Help with W6!!!
Posted by Haas on August 25, 2003 at 05:51:28 from (12.65.44.102):
In Reply to: Need Help with W6!!! posted by Dave Wiley on August 24, 2003 at 19:54:00:
I all is set up correctly, connecting the battery either positive or negative ground will work. However, I expect the W-6 was originally positive ground. You don't say if you have battery ignition or a magneto or if you have original 6 volt generator or has been converted to a 12 volt alternator. However, it sounds as though your generator is not charging the battery and your ignition is running the battery down after a time. Things to check. Does your amp gage show charge?? If you have a generator, is it correctly polarized. If you have a generator and it does not show charge on the ammeter, then you can check the generator by grounding the field terminal (carefull not to ground anything else) With the field terminal of the generator grounded you should get max charge rate of around 10 to 15 amps if you have the original generator. If you don't, likely the regulator or the cut out relay is bad. Hope this helps.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
