Re: 51 farmall gas m
Posted by Bob M on August 25, 2003 at 12:48:22 from (165.170.128.66):
In Reply to: 51 farmall gas m posted by rb on August 25, 2003 at 11:52:38:
Sounds like a stuck regulator alright! Try disconnecting the wire to the "GEN" terminal at the regulator. If the ammeter returns to 0 it means the cutout relay inside the regulator has stuck closed. Best fix is to simply replace the regulator.
Post A Followup
: Re: Re: 51 farmall gas m
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
