Re: Problem With 2-14 IH 3-point Plow
Posted by Hugh MacKay on August 26, 2003 at 18:14:55 from (209.226.106.174):
In Reply to: Problem With 2-14 IH 3-point Plow posted by Jim Allen on August 26, 2003 at 13:32:57:
Jim: Do you have the equipment to post a picture of this plow? What make and model of tractor are you using? What is the center to center setting of your rear tractor wheels? Does this plow have a tail wheel or long landside on rear bottom? Are you trying to use stabilizers thus trying to hold the plow rigid?
I rather doubt that your plow is cobbled up hitch, as you stated several identical plows at auction. My guess is your problem lies in settings and wear parts or a combination of both. My opinion is if anyone is going to help we need more info. Answer the above questions will give a start.
Post A Followup
: Re: Re: Problem With 2-14 IH 3-point Plow
