Re: Second generator still no charge-HELP!
Posted by Bigdog on August 28, 2003 at 16:06:46 from (24.160.187.13):
In Reply to: Second generator still no charge-HELP! posted by Bob Quale on August 28, 2003 at 14:29:35:
Ground the field terminal. If it charges, your problem is in the regulator or connections. Bob Melville has a troubleshooting chart which should help you. Check the link
Post A Followup
: Re: Re: Second generator still no charge-HELP!
