Re: H Transmission seals
Posted by Jim In Ontario on August 28, 2003 at 20:54:57 from (216.58.103.52):
In Reply to: H Transmission seals posted by brad on August 28, 2003 at 14:05:51:
I Just changed the seals in mine and did not have to split the tractor, The only glitch that I had was that I had to make the gaskets as they were not available from International Harvester.
Post A Followup
: Re: Re: H Transmission seals
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
