Oil Pressure on Farmall C
Posted by dw on August 29, 2003 at 03:30:56 from (66.157.145.208):
I have reworked the engine in a Farmall C (c123). After replacing rings, rod bearings and main bearings and all gaskets, I have no oil pressure. I removed the oil pump and looked it over. Seems to be solid with no warps in the flat plate. (I replaced the thin gasket.)
Any ideas of what might be the problem?
Thanks a million!
Post A Followup
: Re: Oil Pressure on Farmall C
