Re: Oil Pressure on Farmall C
Posted by mbnok on August 29, 2003 at 21:18:54 from (65.168.67.54):
In Reply to: Oil Pressure on Farmall C posted by dw on August 29, 2003 at 03:30:56:
Do what Brian said. You can also just leave the gauge out and start up believe me the oil will fly out if the pump is working. I saw a c once that would do that with no pressure. (Still could have been the gauge). If you had pressure before you reworked it you have to start looking so try the pump in tractor or a bucket and go from there.
Post A Followup
: Re: Re: Oil Pressure on Farmall C
