Re: Second generator still no charge-HELP!
Posted by Haas on August 29, 2003 at 05:36:06 from (12.65.2.201):
In Reply to: Second generator still no charge-HELP! posted by Bob Quale on August 28, 2003 at 14:29:35:
Do you have a new paint job on your tractor?? In order to work correctly, the mounting feet of the voltage regulator must have a good ground. New paint is enough to stop the system from charging. If you have mounted the regulator on new paint, try running a wire from the mounting foot of the regulator to the battery ground and see what happens.
Post A Followup
: Re: Re: Second generator still no charge-HELP!
