Re: mower under cub
Posted by Buzzman72 on August 29, 2003 at 06:37:47 from (67.241.50.49):
In Reply to: mower under cub posted by MWKellner on August 28, 2003 at 09:09:14:
What it sounds to me is that you have a Woods 42 (actually a 3-1/2' mower), by the shape of it. If it has a single pulley and spindle in the middle, and an opening to the front of the spindle to access the blades; and the blades are removed by removing a 5/16" cap screw, then pivoting the block the bolt attaches to, to expose a pin of about 3/4" diameter that retains the blades (if memory serves me correctly...sixes here are approximate); then you definitely have a Woods 42. The Woods 42 was about the ideal size mower for a Cub, if you planned to mow anything more than a slightly overgrown lawn. Under ideal conditions, the Woods 42 was like a belly-mounted bush hog for a Cub!
Post A Followup
: Re: Re: mower under cub
