Re: Re: Re: Second generator still no charge-HELP!
Posted by Bob M on August 29, 2003 at 06:54:13 from (165.170.128.66):
In Reply to: Re: Re: Second generator still no charge-HELP! posted by Bob Quale on August 28, 2003 at 16:31:39:
Bob - That troubleshooting guide is for a regulator-equipped system. If your "regulator" has no FLD terminal, it's actually a cutout. Troubleshooting a cutout is a bit different... here's what I'd suggest: With the motor stopped, connect a jumper wire from the generator F terminal to a GOOD ground - the grounded battery post is best. Now run the motor at ½ throttle or faster, and with an assistant watching the ammeter connect another jumper between the BAT and GEN terminals at the cutout. If the generator is good, the ammeter will show a decent level of charge (+10 amps or so). It also means the cutout is either bad or is not properly grounded as Haas suggests. However if you get nothing or a discharge indication when you make the connection, the generator is bad. If the generator tests OK, then the problem has gotta be in the charging system F circuit. If you have an ohmmeter you can test it like this: Remove the wire from the generator F terminal. Connect one ohmmeter lead to the disconnected F wire and the other to a GOOD ground. With the headlight switch in the L (low charge) position, the ohmmeter should read around 2 or 3 ohms . In the other three positions (H, D and B) the meter should read close to 0 ohms. If the readings are higher (or infinity) either the switch is bad or the switch is not grounded, again as Hass suggests. If it turns out the problem is the light switch and you don't want to mess with it, you can simply permanently ground the generator F terminal. This set the generator to "high" charge full time. Unless you the tractor for hours on end, it will work fine this way. Just check the battery water level occasionally and refill if it gets low. Hope this helps!
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
