Re: 354 Diesel
Posted by JB on August 30, 2003 at 17:24:47 from (24.157.142.242):
In Reply to: 354 Diesel posted by Maury on August 30, 2003 at 15:30:52:
It has been a few years since I worked on a 354D but is yours the British built 154 CU In Diesel with a CAV injector pump ? Do a quick check on the fuel shut off rod on top of the injector pump that it is functioning properly. Had the key come out one time and it stayed in the shut off position. Sounds like a fuel problem to me. First of all check for clogged fuel filters. Replace them if necessary. Then you will have to bleed the fuel system to get the air out. There is a hand pump on the fuel pump on the side of the engine block to manually pump fuel through the system. First you have to get the air out of the fuel filters, there is a bleed screw on top of the filter, open it and pump the hand pump until air bubble free Diesel fuel comes out, then shut this bleed screw and repeat the process with the bleed screw(s) on the injector pump. I can't remember if this pump had a bleed screw on the primary and another on the secondary. Some of these tractors will start now but others require bleeding the injector lines. We had a B414D and a 434D which were indentical except for the skins. The B414D would start without bleeding the injector lines and the 434D you had to bleed at least 2 injector lines. BE CAREFUL THE DIESEL FUEL FROM THE INJECTOR PUMP IS UNDER HIGH PRESSURE. To bleed injector line, loosen one of the nuts on one of the injector feed lines out of the injector pump. Then crank the engine over with the starter and when fuel is sprayed out, tightent this nut and repeat for the other 3. If you do not get any fuel spraying, either you didn't get your fuel system bled properly or inject pump is not working. Good luck JB
Home
| Forums
Today's Featured Article -
Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
