Re: Re: 354 Diesel
Posted by Maury on August 30, 2003 at 23:55:35 from (198.81.26.207):
In Reply to: Re: 354 Diesel posted by JB on August 30, 2003 at 17:24:47:
JB thanks for the info is does have the CAV Pump however the fuel system is fine (I opened the bleed screws on the filter and on the pump and just got fuel no air. So it seems to be getting plenty of fuel. I also checked the fuel shut off rod it is working correctly that's why I thought maybe it jumped timeing. It ran for about 30seconds and then died - like it was just cold but it just won't re start. It haas never done this before at first I thought maybe the fuel valve was close but it is open and flowing fine.
Any other ideas of what to check? the glow plugs are glowing it has fuel, I am breathing so it has air by all accounts it should run. I must be over looking something...
Post A Followup
: Re: Re: Re: 354 Diesel
