Re: injector pump400
Posted by Jimmy King on August 30, 2003 at 21:33:04 from (63.189.32.231):
In Reply to: injector pump400 posted by Max Adams on August 30, 2003 at 20:45:53:
This is an IH pump if you have a service manual it sould have a break down on it you can do anything you need to except run it on a test stand. We had a 400D it probably has a 450 kit in it if it has been overhauled. Had 15.5x38 on back it would hold its own on a 7ft. Roam offset plow, and burn about 2 gal per hr on it.
Post A Followup
: Re: Re: injector pump400
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
