Re: 140 Steering Problem
Posted by Farmer Bob on August 31, 2003 at 20:38:45 from (64.113.13.127):
In Reply to: 140 Steering Problem posted by Tim on August 31, 2003 at 20:29:27:
Most likey the worm gear on the steering shaft or the steering gear have worn to the point of replacement. Just went through this on my 340D which is similar in design. That collar is what keeps the balls in the bearing so you can't pin it solid to the shaft. This all assuming the woodruff key is the one at the first spider gear behind the bolster.
Post A Followup
: Re: Re: 140 Steering Problem
