Re: Re: Re: Re: Re: Re: Re: Second generator still
Posted by Jacques on September 01, 2003 at 17:40:59 from (208.180.68.32):
In Reply to: Re: Re: Re: Re: Re: Re: Second generator still no posted by Bob Quale on September 01, 2003 at 06:43:30:
Bob, someone may have mentioned this already, but here goes. Make sure the wires to/from the gen/regulator, etc., are not splice with crimp-on splices. These are ok for a while if done properly, but the best connections/splices are soldered! If you've got a few old crimp-on splices in your generating or ignition wiring, replace them. Also make sure you've got the right size wire for the job. Just one or two old, corroded or improperly done splices will be enough to drop voltage, overheat and maybe even cause a fire. After you fix the generating problem, recheck the wiring and replace any wire that's seems questionable. Good luck.
Post A Followup
: Re: Re: Re: Re: Re: Re: Re: Re: Second generator still
