Re: IH 2500B Trans.Problem
Posted by RAS on September 02, 2003 at 21:07:33 from (66.87.12.37):
In Reply to: IH 2500B Trans.Problem posted by Mike Groom on September 01, 2003 at 17:42:38:
The on the bottom of the trans you should find a valve. Remove the nut to remove the regulating valve & you might find the spring broken. You can get a kit to repair. This trans is the same as the T.A. trans without the sprag clutch. (one way bearing)
Post A Followup
: Re: Re: IH 2500B Trans.Problem
