Re: Help with w6
Posted by BIG JOHN on September 03, 2003 at 15:31:03 from (205.188.209.140):
In Reply to: Help with w6 posted by darind in WA on September 02, 2003 at 21:27:43:
I think that you should rethink trying to add a 3 point hitch to this tractor. Hydraulics is not a problem, there are several options. The 3 point hitch is the PROBLEM. This tractor was designed as a pulling tractor, ie. plows, disc's, etc. The operators seat is located back of the rear axel where the 3 point hitch would have to be attached. This would put you right in the middle of the hitch, not a real safe place to be. Also the tractor is mounted from the rear which would be a pain with a 3 point hitch to climb over. You would probably have to remove the fenders and the platform back of the rear axel. Trail or drag type blades are available, which in the long run be a cheaper arangement for you. Wouldn't be as easy to back up with as a 3 point and you wouldn't be able to push with it, only pull. GOOD LUCK
Home
| Forums
Today's Featured Article -
Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
