Re: 454 hyd. brakes
Posted by JB on September 03, 2003 at 17:55:51 from (24.157.142.242):
In Reply to: 454 hyd. brakes posted by Ray on September 03, 2003 at 12:49:18:
Hi, it is important to use only IH Hytran hydraulic oil. My brother learned the hard way. He purchased a used wood splitter at an auction sale, not thinking he attached it to his 454 and all the oil in the wood splitter mixed with the Hytran and started to foam. Then air bubbles in the brakes etc. Hints on bleeding the brakes: 1) Transmission fluid must be warm. 2) Run engine at fast idle 1300 RPM. 3) Loosen both bleed screws and connect a clear plastic tube onto the bleed screws and put the other end into a clean contianer to catch the Hytran fluid. Now my brother just lets the fluid flow until there are no more air bubles and closes the bleed screws. He does not pump brakes or pinch off the brake return line in front of the battery box. The book tells you to pinch off the brake fluid return line and to pump the brakes. As for the cause, it could be wrong hydraulic oil but most likely with a 454 it will be worn brake master cylinder or piston seals. Search this form for archive records for 454, 574, 684 they all have the same rear end just different engines. Good luck JB
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
