Re: What should My piston rings look like
Posted by parts man on September 03, 2003 at 19:29:42 from (207.179.165.97):
In Reply to: What should My piston rings look like posted by Bob Quale on September 03, 2003 at 13:46:12:
Bob, DO NOT! hone the cylinders if you don't replace the rings. The W4 has a sleeved engine so you don't have to worry about oversize etc. Since you have the engine apart anyway I would replace the rings and hone the cylinders though. You have to buy the Gaskets anyhow and in Canada the rings are only about $60, in the States should be less. They should be availlable at a good auto parts store or definetly at your IH dealer.
Post A Followup
: Re: Re: What should My piston rings look like
