What should My piston rings look like
Posted by Bob Quale on September 03, 2003 at 13:46:12 from (208.164.49.189):
Well I ordered the valves and guides for my W-4 and figured I might as well pull the pistons and check the rings as long as I have to wait for the parts.
What should the rings and oil seal look like, so I will know if they need to be replaced or not?
Can I reused them if they look ok? Should I hone the cylinders?
Bob
Post A Followup
: Re: What should My piston rings look like
