Re: Auxillary Fuel (belly mounted) Tanks - 66 Seri
Posted by farmerbill on September 04, 2003 at 19:29:46 from (198.88.216.33):
In Reply to: Auxillary Fuel (belly mounted) Tanks - 66 Series posted by Mitchissippi on September 04, 2003 at 11:07:48:
Had one of those tanks and liked it. It wasnt factory but a aftermarket. It was no problem changing hyd filters. It would let you run all day without any trips to the fuel barrel. As far as being vulnerable I would disagree. It was heavy gauge material for a fuel tank and I'm sure it withstand far more abust than the poly tanks on the magnums we use today. I cant believe I never poked a hole in a 86 series tank. Never did like the front tanks. Obstructed the air flow and caused the tractor balance to change more than I figured. Just my thoughts.
Post A Followup
: Re: Re: Auxillary Fuel (belly mounted) Tanks - 66 Seri
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
