Re: Farmall 706 wont turn over, was fine.
Posted by Jimmy King on September 07, 2003 at 20:21:50 from (63.186.40.12):
In Reply to: Farmall 706 wont turn over, was fine. posted by Matt on September 07, 2003 at 19:18:30:
Are you pushing in the clutch some of them still are hooked up to the safety switch. If you are I would start with the starter button short across the terminals on the back of the button assembly. Please make sure it is in netural That is the reason for the clutch safety switch. I know a man that was permanently crippled when he shorted across the selnoid and a 4020 and disc harrow ran over him. Saftey switch can be bad also. If it is not the things I have listed not likley but could be key switch. then you are to starter or battery.
Post A Followup
: Re: Re: Farmall 706 wont turn over, was fine.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
