Re: adding power steering
Posted by Aces on September 08, 2003 at 13:52:45 from (67.0.36.244):
In Reply to: adding power steering posted by jake on September 08, 2003 at 10:37:05:
Jake the power steering was a behlen, it used a flow devider valve to sent 2 / 3 galons to the power steering unit so you will need the flow devider off his 400 his front steering shaft or cut yours and put key way in it hoses from the low devider. Some braces for the behlen. Hope this helps some
Post A Followup
: Re: Re: adding power steering
