Farmall Tractors Discussion Board
Re: Re: Re: Alternator Problem - 10-S1 Type
Posted by Ralph on September 25, 1999 at 17:36:12 from (207.109.126.24):
In Reply to: Re: Re: Alternator Problem - 10-S1 Type posted by Village Blacksmith on September 25, 1999 at 16:16:01:
Here is a web site that may be of help, http://www.oldengine.org/unfaq/10si.htm Also you didn't mention if it didn't start charging at idle or didn't charge at high idle. They have to turn fast enough it get them excited then they will charge at lower idle. Also we install a diode instead of the switch to stop feed back. Good luck Ralph
Post a Followup
: Re: Re: Re: Re: Alternator Problem - 10-S1 Type
