Farmall Tractors Discussion Board
Re: Re: Alternator Problem - 10-S1 Type
Posted by Village Blacksmith on September 25, 1999 at 16:16:01 from (152.163.204.207):
In Reply to: Re: Alternator Problem - 10-S1 Type posted by ltf in nc on September 25, 1999 at 07:14:57:
It is a Delco-Remy alternator with internal regulator. I did install a new plug-in connector.
The red wire is connected to the battery terminal on the alternator, along with the main wire connected to the left side of the amp meter. The white wire is connected through a toggle switch to the ignition switch. The toggle switch is to kill the alternator so that you can shut down the engine when you turn off the ignition switch. Otherwise, the feed back will keep the engine running even though the ignition switch is turned to the off position.
Post a Followup
: Re: Re: Re: Alternator Problem - 10-S1 Type
