Re: super A hydraulic problem
Posted by scotty on September 09, 2003 at 11:43:26 from (199.231.49.128):
In Reply to: super A hydraulic problem posted by patpeery on September 09, 2003 at 10:02:03:
Pat,
The strainer screen is on the carb side of the unit, four screws. I dont know if you have the same problem that I have, the o rings on the pump under the mag are shot allowing hyd fluid back into the crankcase. You might check that also. You can get the complete rebuild kit from Case IH.
Post A Followup
: Re: Re: super A hydraulic problem
Today's Featured Article - Talk of the Town: Repairin a Gas Tank - by Staff. This interesting discussion is from the Tool Talk Discussion Forum. Remember that safety is your first priority - make sure you know what you are doing before attempting a potentially dangerous activity! ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
