Re: steering u-joints
Posted by Theman on September 10, 2003 at 08:34:18 from (65.248.77.5):
In Reply to: steering u-joints posted by Eric on September 09, 2003 at 21:52:01:
Most likely all you need is the cross for the u-joint. I bought one for my H at the local TSC store. I have no reason to believe the M is any different. Take the forged yoke piece with you to match up the size. It used the same clips that go inside the yokes as the original. The only thing to be careful with during assembly is making sure the grease fitting is on the correct side.
Post A Followup
: Re: Re: steering u-joints
