Re: Generator Difference: H and BN
Posted by gene b on September 12, 2003 at 04:30:49 from (65.227.53.79):
In Reply to: Generator Difference: H and BN posted by Steve W on September 11, 2003 at 11:35:51:
They are not the same check out the numbers on the plate then go with the correct regulator. The outputs are different as the one for the H will put out more current. Ihave the DELSO REMY listings andmost places will list two regulators make sure you get the right one for your gen If you need more info send an E-mail
Post A Followup
: Re: Re: Generator Difference: H and BN
