Re: Torque values for Farmall A manifold
Posted by Randy in NE on September 12, 2003 at 04:36:06 from (216.58.237.20):
In Reply to: Torque values for Farmall A manifold posted by Gerald on September 11, 2003 at 20:05:49:
I just replaced the head gasket on my '50 C. It has the same 113 cu. in. motor that the A has. The spec sheet calls for 20 ft-lbs. I started at the center and worked out in each direction. My manifold was semi-split into three sections with two studs for each section.
Post A Followup
: Re: Re: Torque values for Farmall A manifold
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
