Re: Help! 450 Hydraulics Problem
Posted by Evans on September 12, 2003 at 08:50:50 from (216.114.249.4):
In Reply to: Help! 450 Hydraulics Problem posted by Al on September 11, 2003 at 17:53:07:
probably too much leakage past the control valve spools due to wear.you will have to enlarge the orifice in the pressure regulator valve to overcome this.This orifice can be removed with a screwdriver after taking the cover off.You will need a new gasket.Do not enlarge it too much or you can't get it on high pressure.
Post A Followup
: Re: Re: Help! 450 Hydraulics Problem
