water pump for an A?
Posted by Brad on September 12, 2003 at 11:16:05 from (168.8.170.13):
My 1946 A has a thermosiphon cooling system; however, I have seen aftermarket water pumps for the A series listed on eBay and in catalogues. Is there any advantage to retrofitting an A with a water pump or do they do just fine as they are? Mine was built as a distillate tractor and has the original all-fuel manifold, pistons, and radiator shutter.
Post A Followup
: Re: water pump for an A?
