Re: Farmall 300 cotton tractor....
Posted by NDS on September 13, 2003 at 17:11:59 from (64.12.97.13):
In Reply to: Farmall 300 cotton tractor.... posted by Jesse on September 13, 2003 at 14:30:28:
To change direction of travel on low drum you removed ring gear and switched it to opposite side of pinion. This required gear shift to moved to side away from pinion shifting forks were not reversable and different set was required for each side(at least on H and M not sure on 300). This is true for low drum picker only on high drum direction was changed in special drop axles remove drop axles and mount wheels in normal way and tractor would travel forward. Most high drums were mounted on M or larger tractor 300 most likely was low drum. To chande high drum to forward travel high clearance you left drop axles in place and used reversing kit from low drum to get forward travel the tracor wae essentially reversed twice.
Home
| Forums
Today's Featured Article -
Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
