Re: Re: Re: 400 Water Pump
Posted by Tim Kincaid on September 13, 2003 at 18:41:01 from (12.217.168.45):
In Reply to: Re: Re: 400 Water Pump posted by Russ Vetter on September 13, 2003 at 18:21:08:
Russ,
The piece your trying to remove is the packing nut I believe from your discription. It is threaded and can be removed by turning it counter clockwise with the pump clamped down to the bench or in a vise. Use a big channel locks and be easy with it. You said you had a noise in the pump you thought but check the generator also, sometimes that front bearing in the generator will get noisy and telephone noise thru the belt fooling some people. If you need more advice on it I have rebuilt several of those and will help you thru it . Email me directly at tkincaid65@hotmail.com See Ya Tim K.
Post A Followup
: Re: Re: Re: Re: 400 Water Pump
