Re: Farmall 450 hyd leaks
Posted by 26Red on September 23, 2003 at 12:35:40 from (170.92.1.104):
In Reply to: Farmall 450 hyd leaks posted by Adam R on September 23, 2003 at 08:57:16:
I do not have a 450, but I have a 300 row crop which is similar. I have been chasing leaks too in that same area. If you already have the dash and cowel off, the rest of the work is pretty easy. Just remove the control rod assembly, and then remove the four large nuts on the right side of the valve bank and slide each valve assy off. O-rings are used in between the valve assys. Other areas check for leaks would be: 1. the rear output lines. 2. the supply lines to the reservoir-o-ring ports. 3. oil pressure gage line- mine was leaking. Hope you have better luck than me, these hydraulic leaks are driving me crazy. I am about ready to replace all the steel lines with new custom built ones this winter.. at least the engine doesn't leak oil.. Is there a dye I could add to the hydrualic oil to find the pin hole leaks in the steel lines?
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
