Re: snapped that puppy right off!
Posted by sod on September 25, 2003 at 08:34:13 from (209.206.151.77):
In Reply to: snapped that puppy right off! posted by riverrat on September 24, 2003 at 20:09:55:
May I say that I would rather have a cheaper bolt break off in that spot, than have the loader or tractor break. It isn't a bulldozer, you know.
good luck
sod
Post A Followup
: Re: Re: snapped that puppy right off!
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
