Re: Problems with154 starting
Posted by mike on September 26, 2003 at 07:18:31 from (198.208.223.46):
In Reply to: Problems with154 starting posted by 49 Cubber! on September 26, 2003 at 06:53:00:
couple of things to check. Do a voltage drop check on the + & - battery cables. To do this use a volt meter with the + lead on the battery terminal. The volt meter - lead on the starter terminal. Crank the starter and the meter will read the voltage drop if it reads more the .2 volts this could be the problem do the same measurement on the ground side. This will show any bad connections or bad cables. Another area to look at is sometimes carbon will build up under the rings and cause the rings to expand when hot. Several companys make a top engine cleaner you can pour in through the carb "almost impossible on a cub" to clean the carbon out.
Post A Followup
: Re: Re: Problems with154 starting
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
