Re: Problems with154 starting
Posted by Gary_N_WV on September 26, 2003 at 07:43:14 from (129.71.234.254):
In Reply to: Problems with154 starting posted by 49 Cubber! on September 26, 2003 at 06:53:00:
Get a set of jumper cables, and by-pass all the wiring and solenoid from the batt.to the starter.(expect a pretty good spark when you connect the jumper to the starter terminal.....don't hook to your starter first and then your batt. ....hook the cable on the battery first...then the starter last for safety reasons.)
This will eliminate any faulty wiring, solenoid and battery cables.
make sure that you also ground the "gounded terminal" to the frame.
If she won't turn over then, take the starter back and have it rechecked.
Just guessing here, but....if all wiring etc is good as you say, it sounds like the starter has a problem that only shows up under a heavy load.
I've had car starters do that on a few occasions.....work fine when engine is cold, but not crank a warm engine.
Oh yeah....re-check your timing...too far advanced...can cause this also.
Hope this helps some !
Gary
Post A Followup
: Re: Re: Problems with154 starting
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
