B414 glow plug voltage
Posted by Geoff on September 27, 2003 at 05:53:20 from (216.113.12.175):
My B414wiring needs work and the glow plug indicator
thingee has crapped out. I would like to put a resistor
in-line to reduce the voltage as the replacement plugs I
was sold seem to have 9v stamped on them. What is
the actual voltage at the glow plug. I know from painful
experience that 12 v is TOO much.
Post A Followup
: Re: B414 glow plug voltage
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
