Re: B414 glow plug voltage
Posted by Gary-Miss on September 27, 2003 at 07:21:02 from (205.188.209.140):
In Reply to: B414 glow plug voltage posted by Geoff on September 27, 2003 at 05:53:20:
The B-414 glowplugs are in series, only the front one is grounded. You don't need a resistor. I did away with the original glow plug switch on mine and installed a foot starter switch in the same place. Most of the time, when you start having glow plug burnout problems on the B-414 as well as its sister tractors, such as the 424, the precombustion chamber is full of carbon and needs to be cleaned. This stoppage will also cause excessive smoke.
Post A Followup
: Re: Re: B414 glow plug voltage
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
