Re: C oil pressure ?
Posted by CNKS on September 27, 2003 at 14:04:02 from (207.178.96.212):
In Reply to: C oil pressure ? posted by Gary_N_WV on September 27, 2003 at 13:53:38:
I like to see them on the outside of the L, but if it runs there after it is hot, meaning after running 30 minutes or so you are OK. I have a Super A that needs engine work, third in line at the moment, that drops substantially when it is run for a while. This is an indication of the need for engine/oil pump work. Without looking it up, I believe the operators manual shows the needle in the middle.
Post A Followup
: Re: Re: C oil pressure ?
