Re: 6 TO 12 VOLT H
Posted by Steve - IN on September 28, 2003 at 08:15:59 from (12.222.30.13):
In Reply to: 6 TO 12 VOLT H posted by PHILLIP on September 27, 2003 at 19:16:37:
Phillip, I'm with the other guys -- and a couple of other items to add. The H generator will do 14 or more volts unregulated. You simply need to change the regulator to make it work at 12. To Hugh's point, the stock generator won't go much north of 20 amps (thus the 20 +/- on the ammeter). Even small, cheap alternators will produce 45 amps - lots more extra power to charge the battery, even when the lights are on all the time. If you have a coil/distributor ignition, and are going to 12V; you'll need a dropping resistor to keep the feed to the existing coil at 6V. If you're hot to rebuild something, rebuild that old starter motor. Easily turning bearings and good brushes make it spin lots easier; meaning the 6V system can turn the engine as fast as any 12V conversion. The fat cables and clean connections need to be there, like James says; but the crux of any starting system is the starter motor - so concentrate on it. As for the low buck horsepower: that's the holy grail of every hotrodder. Talk to most of 'em and you might hear that the biggest bang for the buck is a nitrous oxide bottle. You basically double the percentage of oxygen in the air -- result is bigger explosions. Downside is rapid heat increases in the head. Short of that, the cheap way to help any engine is to make it easier to inhale cold, clean air and exhale the burnt gas. All depends on how original you want to keep it, what and where you intend to use the torque or horsepower - and your taste for cubic dollars.
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
