Re: Clutch problem with Super C
Posted by Richard Fazio on September 29, 2003 at 08:02:21 from (63.126.80.2):
In Reply to: Clutch problem with Super C posted by Ken on September 28, 2003 at 09:47:31:
I just replaced a clutch on an 8N that was stuck. It was rusted on as Josh said. After spitting the tractor I thought I could have fixed it without splitting her. I tried all the draggin' around and driving with the clutch in stuff. Nothin' worked on mine, it was stuck good. I think if you can pull the starter and have access to a small part of the disk you could pry it apart slowly with a screw driver or blade. You may be able to gain access through the inspection cover on the bottom of the bell housing, if your tractor has that. Have the clutch tied down all the way. If you can see the disk between the pressure plate and fly wheel you should be able to pry and turn the flywheel. Pry again. slowly work your way around the flywheel. I don't know what the pressure plate on your tractor looks like but I would think you could do this. On mine the disk was stuck to the flywheel. The pressure plate was free. Also if you adjust your clutch so there is NO play you will get a little more space to pry, Then if you free it re-adjust the clutch to the normal play.
Home
| Forums
Today's Featured Article -
The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
