300 utility clutch
Posted by Dan (nj) on September 29, 2003 at 10:11:54 from (155.94.62.221):
My brother just aquired a 300 utility with a T/A. The clutch doesn't quite disengage to shift but it doesn't grab until the pedal is almost up. Will the clutch work without the T/A? The handle is missing and I understand that to adjust the clutch you have to adjust the T/A. Also when the pedal comes up just a little you can hear gears rubbing that sounds like the PTO going into gear. The PTO seems to be "on" all the time, even with the lever "off". Any help will be appreciated and, yes I know, we need to get a manual. We just can't wait. Thanks, Dan.
Post A Followup
: Re: 300 utility clutch
