Re: 300 utility clutch
Posted by Aces on September 29, 2003 at 10:29:12 from (67.0.36.244):
In Reply to: 300 utility clutch posted by Dan (nj) on September 29, 2003 at 10:11:54:
The TA needs to be adjusted even if you don't use it because if not it can make the gears hang bad and hard to shift if the clutch does not engage till all moust the way up sounds like main clutch is getting close to being gone. the main clutch has nothing to do with PTO if PTO runs all the time the brake is not holding.
Post A Followup
: Re: Re: 300 utility clutch
