Re: Is webbing strap OK for pulling small stumps,
Posted by gm on September 29, 2003 at 16:15:49 from (67.50.125.121):
In Reply to: Is webbing strap OK for pulling small stumps, etc? posted by TedM on September 29, 2003 at 05:10:19:
I have found anything non-metal tends to break.
I think the ratings for them are not the same as for chain. Or perhaps they just generally underrate chains and overrate straps.
Even chains break but I have better luck with them. If you are concerned about it snapping up at you, just add a bunch of weight to the middle. I believe that should keep it from flying up at you. -Greg
Post A Followup
: Re: Re: Is webbing strap OK for pulling small stumps,
