M radiator studs
Posted by old on March 30, 2009 at 17:36:22 from (4.245.5.85):
When I pulled the radiator off this M to replace the water pump both of them broke off about 1/4 inch from the bottom of the radiator. Now if this was some where on the block etc I would weld a washer and then a nut on and have no problem but can I do this safely on the radiator with out making it leak??
Thanks
