Re: M radiator studs
Posted by leroy in ne on March 30, 2009 at 18:57:45 from (67.63.106.62):
In Reply to: M radiator studs posted by old on March 30, 2009 at 17:36:22:
just a thought for you to think about. cap or plug both hose connections, fill radiator completely full. cap and turn radiator over, leave at a slight angle and weld away. water will keep solder cool enough it won't melt. pressure cap will releive any expansion so radiator doesn't blow a seam. i can't see what you are working with but by your description this might work
