Re: Re: Re: 6 TO 12 VOLT H
Posted by Hugh MacKay on September 30, 2003 at 02:32:15 from (216.208.58.122):
In Reply to: Re: Re: 6 TO 12 VOLT H posted by David Knapp on September 29, 2003 at 20:12:00:
Danid: If you go to Google search, type in 6 volt alternator, you will very quickly have the name of a supplier of 6 volt alternators.
Yes you do have to change to negative ground. Another thing I do is put a push button type switch on dash for exciting alternator. The reason for the push button switch is you just a shot of current just after tractor starts, but you also can't forget and leave that switch on as it will drain battery when tractor is not in use. The excite switch is quite easy as when you install alternator you have an extra wire in harness.
Post A Followup
: Re: Re: Re: Re: 6 TO 12 VOLT H
