Re: Farmall 560 SMOKE!!!
Posted by David in MS on October 01, 2003 at 15:16:21 from (65.135.74.80):
In Reply to: Farmall 560 SMOKE!!! posted by David in MS on October 01, 2003 at 05:41:32:
Ok, after further review, When I said high idle I meant full throttle. The smoke is white. If it were a head gasket and that was water burning in the exhaust and there were no other leaks on the tractor this should show up in the water level in the radiator shouldn't it? I appreciate all the input and look forward to more.
Post A Followup
: Re: Re: Farmall 560 SMOKE!!!
